How to show Matrix array on Freemaster
1,533 次查看
Davidino
Goodmorning,
I'm using Freemaster version 3.2.0.5 succesfully, except for the following struct:
typedef struct
    DIRECTION direction;
    int16_t encoderEventImpulses[ARRAY_SIZE_MOTORS][MAX_NUM_OF_ENCODER_EVENT+1];
    bool encoderEventEnable[ARRAY_SIZE_MOTORS][MAX_NUM_OF_ENCODER_EVENT+1];
    uint16_t encoderEventSize[ARRAY_SIZE_MOTORS];
    int16_t angleLoaded[ARRAY_SIZE_MOTORS];
    bool changeSign;
    uint16_t angleEnabledCounter;
    uint16_t angleUsableIndex;
	NUMMOT motorNum;
	uint16_t numOfEncoderCompareAngleChangedListener[ARRAY_SIZE_MOTORS];
}tEncoderEvent;
As you can see some struct members, such as encoderEventImpulses, are array matrixes.
How can I show this kind of values on Freemaster?
Thank you in advanced.
Davidino
0 回复数
