Dear NXP Technical team,
When installing the FreeMASTAR Lite, license Activation Code is required.
When I visited The address, I was prompted. The software licensing and registration system is currently unavailable. Please try again later.What should I do
https://www.nxp.com/webapp/swlicensing/sso/downloadSoftware.sp?catid=FreeMASTER_Lite_1.2.RTM
解決済! 解決策の投稿を見る。
Hi @linhong,
I just checked the link on my side and it is functional. Could you try accessing it again and let us know if you are facing the same issue.
Kind regards,Iulian
