CAN Calibration Protocol
ソリューションへジャンプ
2,505件の閲覧回数
wangyanjun
pcm_ug.pdf 2.5 said there are communication plug-in for CAN calibration protocol. Where can i find this plug-in? How to use it?
2,486件の閲覧回数
MichalH
NXP Apps Support
NXP Apps Support
Hello wangyanjun,
the last development around CAN Calibration Protocol is dated back to 2002. Indeed, we did have a plug-in which has enabled FreeMASTER to use CCP SET_MTA, UPLOAD and DNLOAD commands to access the target RAM. It has also used the ACTION SERVICE command to implement other FreeMASTER protocol services.
Later this plug-in was replaced completely by a custom FreeMASTER-over-CAN plug-in. It is not distributed and supported anymore.
Michal
2,486件の閲覧回数
MichalH
NXP Apps Support
NXP Apps Support
Hello wangyanjun,
Michal
