Not getting serial monitor window on USB host for Teensy 4.1
1,216 次查看
pruthashinde
I'm working on Teensy 4.1. There are two USBs on this board. One is a Micro USB and another is a USB host. I'm able to flash the code through Micro USB as well as able to get a serial monitor window using the same cable.
But now I want to get a serial monitor window using a USB host. As I'm new to this platform I'm not able to do it. Can anyone please give me some pointers regarding this problem? Requesting you to please guide me about the required connections on the Teensy 4.1 board too.
Teensy 4.1
IMXRT1061
Thank you in advance.
0 回复数
