PTN3460 reading from EXTERNAL EEPROM
1,252 次查看
MaxxCO
I need help with getting PTN3460BS_F6Y reading from external 24LC02 eeprom.
I am trying to transfer video from the pc dp to an LVDS panel that has RxO0, RxO1, RxO2,RxOCLK, RxO3 pairs respectively same for the even pairs. I USE 2 LANE DP AND WHEN THE DEV_CFG IS LOW THE PC DETECTS THE HARDWARE BUT THIS IS NOT WHAT I AM TRYING TO GET.
TESTMODE - LOW
CFG1 - LOW
CFG2 - HIGH
CFG3 - LOW
DEV_CFG - HIGH
CFG4 - HIGH
I HAVE NOT PROGRAMED ANYTHIG TO THE PTN3460 AND I AM NOT SURE IF I AM SUPPOSED TO UPDATE THE FIRMWARE BUT IT SIMPLY DOES NOT WORK. THE PC DOES NOT RECOGNIZE ANY HARDWARE ATTACHED TO IT.
IS THERE SOMETHING I AM MISSING HERE.
PS: PLEASE DO NOT REFFER TO ANY APP NOTES SUCH AS AN11128 AND SO ON, I HAVE THEM ALL.
1,168 次查看
diazmarin09
Hello Maxx,
I hope all is great with you. Thank you for using the NXP communities.
Are you using the DPCD Tool? Could you please share your schematic?
Please review your email. I shared further information.
David
1,248 次查看
MaxxCO
A0, A1 AND A2 PINS OF THE MEMORY ARE CONNECTED TO GROUND, HOWEVER THE DATASHEET SAYS THEY ARE NOT USED .....
