static functions: what this means?
1,502 次查看
E_Dattilo
i've seen in many examples that many functions are declared as "static", for example:
static void MyFunc() {
Could someone explain me what this keyword means? I am not able to find information about it on codewarrior help.
Thank you all,
Erik Dattilo
832 次查看
SimonMarsden_de
Hi Erik
It's a standard keyword in ANSI C.
Used in the context you quote, it means that the function is private to the file which contains it. It you tried to call it from another file, you would get a link error.
It would even be possible (although poor style) to have two functions with the same name in different files, provided that both were declared as static.
Using 'static' for private routines is good programming practice because it helps to keep your code modular.
Simon
