mcf52235
mcf52235
1,733 次查看
michaelkwan
I am currently designing a new circuit board with the MCF52235 device.  And, I ran out of board real estate to fit in a full 26-pin connector to support both debugging and programming/flashing the microcontroller.  What are the minimum signals/pins that I need to implement to support both debugging and programming/flashing functions. Are BDM port signal pin 1 to 10 out of the 26-pin connector all I needed? I can not find a sure/confident answer to support that from my researched resources/documents online.
Thanks!
Michael
1,647 次查看
miduo
Please make reference from attached picture on the minimum BDM signals. Hope it is helpful.
