flas programing
flas programing
4,254件の閲覧回数
fire
  how to do flash programing on coldfire.
I tried and tired with the procedure given by them.
i don't where i went rong.
Please guide me in this issue.
Thank you.
1,856件の閲覧回数
fire
Hai,
Thanks for your responce.I want to do flash programing on EVB 5282 lite.
I want to program in internal flash. I tried with Flasher supplied by coldfire.
But it is not working.
Please give me some idea.
Thank you.
1,856件の閲覧回数
UK_CF_FAE
Hi Fire,
You want to do flash programming.
1) Do you  want to program a ColdFire device or EVB from inside CodeWarrior?
2) Do you want to use an internal flash ColdFire device and use the flash for non-volatile memory, so-called Flash-As-EEPROM???
1) is easy, either with the Flash Programmer inside CodeWarrior, or with the freeware CF Flasher utility on www.freescale.com.
Let us know.
Mark
