Urgent : For setting RTCCR register
2,432件の閲覧回数
roop
Hi all,
I am using a MCF52213 microcontroller, I want implement a RTC module for that I am setting RTCCR register. When I read this register  it always display zero value.
Please help me to resolve this problem.
Roop
4 返答(返信)
1,685件の閲覧回数
mjbcswitzerland
Specialist V
Hi Roop
There are several discussions about the RTC in the V2 MCU devices in the forum. Try the following: http://forums.freescale.com/freescale/board/message?board.id=CFCOMM&message.id=7891&query.id=76784#M...
Mark
1,685件の閲覧回数
roop
hi,
I not able set RTCCR register. In link u are you are tell about the secret bit  , I want to set this bit.
Actually I want to set RTCCR register but any value  I write in this register it always give me a zero value.This register is access in any supervisor mode as written in dataset of MCF52213. Is any special setting is required to write  this register ?
1,685件の閲覧回数
mjbcswitzerland
Specialist V
Have you first enabled the RTC by setting the enable bit (0x80) inthe RTCCTL register?
Do you also have a voltage connected to the Vbat pin?
Mark
1,685件の閲覧回数
roop
A voltage connected to the Vstby and to RTC module we write in RTCCTL =0x80 but when we read this value itis also give zero.
We are also set other register of RTC module and read this registers, they all return zero value .
Coluld you please explain why we are not able to write into any regrister related to RTC ?
