USB on JM Badge
USB on JM Badge
2,262 次查看
baja_usb
Hi, anyone has succeed with CMX Stack and the JM Badge?
Thanks in advance,
1,540 次查看
baja_usb
Freescale's Technical Support suggest to me use the USB Medical Stack, it's very well documented and after make some hardware specific changes in the Card Select and Card Detect signals, I succeeded reading and writing a SD Card on my JMBadge (Rev C) from a host PC.
The documentation explain how to build new applications using the implemented classes (HID, PHDC, CDC, MSD) and even how to build new class drivers.
The Medical Applications USB Stack is here: http://www.freescale.com/webapp/sps/site/prod_summary.jsp?code=MEDICALUSB" rel="nofollow" target="_s...
1,541 次查看
baja_usb
