RTC: Setting time - protection?
2,172件の閲覧回数
vespaman
Is there any preferred way of setting the RTC registers, so that the operation is 'atomic'?
The 52259 rm is not really helpful on this, but I fear that there may be a second change while I am writing the new time.
1,592件の閲覧回数
vier_kuifjes
Senior Contributor I
It might help to write the seconds register first. If you make sure not to write '59' as value, the seconds will not overflow during the write of the other registers.
1,592件の閲覧回数
vier_kuifjes
