Power consumption of MCF54416CMJ250
1,759 次查看
sreejithrnair
@nxp
Could you kindly provide total power consumption of
MCF54416CMJ250
1,709 次查看
Hui_Ma
Please refer chapter 2.3 of MCF5441x datasheet about MCF5441x product power consumption.
For the total power consumption based on used modules, customer could use that specification to calculate the power consumption data.
For example:
In run mode with nominal 1.2V the core power consumption is:
P=V(I)= 1.2(V) * 0.127(A)=0.15W
Wish it helps.
Mike
1,704 次查看
sreejithrnair
Thanks Hui.
1,740 次查看
TomE
Specialist II
That depends entirely on what you have it connected to, what modules inside it you're using, which power modes it is in for how long and how you've programmed it.
Have you read Section 2.3 (Power consumption specifications) in the Data Sheet?
Tom
