MCF52233 - polarity of the phy output led - LNKLED
1,318 次查看
gilfine
Hi, I use MCF52233.
I an interested to invert the polarity of PHY led output (LNKLED) so that led is ON when link is not established and OFF otherwise.
Is there a way to do it ?
Thanks a lot,
Gil
1,104 次查看
TomE
Specialist II
In a word, no. Not in software, unless you reprogram the pins as GPIO and drive them from code. In the case of the Link Led this would be trivially simple as it doesn't have to blink with traffic like the other ones do.
Otherwise just wire the LED to the other rail or add an inverter or transistor!
Tom
1,104 次查看
gilfine
Thanks a lot !
It was very helpful.
Gil
