KEAZ128 board external clock not enabling
3,900 次查看
rohit_rawat
Dear Sir,
I am using KEAZ128 board. When i program the board normally with internal clock, the code works properly. Afterthat i enable 8MHz external clock inside the code and program the board then what i found is, my external clock not enabling in code. Please provide some suggestion. Please find the attachment for connection diagram for crystal OSC.
Rohit
3,887 次查看
Hui_Ma
Do you mean the external 8MHz crystal doesn't work?
Could you check the FRDM-KEAZ board schematics about external 8MHz crystal circuit?
best regards,
Mike
3,871 次查看
TomE
Specialist II
This is a Coldfire forum. You should try to move your question to a Kinetis forum.
Tom
3,888 次查看
Hui_Ma
best regards,
Mike
