How to debug on my K64F on IAR using windows in a virtual machine?
813 次查看
bayrammidassi
Hallo,
i have a problem to debug my Program which is developed on IAR using CMSIS/DAP on windows.
I am using Linux mate as the main OS and Windows in the virtual machine.
The problem is that windows does't detect the USB interface of my card K64F.
I added the card like a shared disc to my virtual machine but it does't work.
Any help?
thanks in advance
726 次查看
miduo
Have you tried the Vmware? From what I know the best way to run a virtual machine with real hardware is to use VMware and run a virtual XP session... it should works good with all sorts of USB drivers that seem to have trouble on win 7 and other virtual machines.. Be warned that VMware must take over exclusive use of the USB ports while running..
