HTTP client implementation in coldfire
vamsidhanunjay
hi,
i am using coldfire V1 MCF51CN128 controller and i want to implement http client in the controller. i need reference API for implementing. Please suggest.
TomE
Specialist II
FNET - TCP/IP Stack
Points to:
http://fnet.sourceforge.net/
You're lucky. Your MCF51CN128 CPU is listed in the above as "Obsolete platforms, available in older FNET releases:", but at least the older versions should drop in and run.
Tom
