ESD Ratings
ESD Ratings
2,620 次查看
ssanathraj
Please confirm ESD(HBM) ratings for below part Number > LS1028AXE7KQA
标记 (1)
2,606 次查看
Hui_Ma
My colleague will support this thread about Layerscape Processor LS1028AXE7KQA ESD parameter.
I would recommend to submit similar thread at Layerscape sub-forum.
Thanks for the understanding.
Mike
2,613 次查看
TomE
Specialist II
This is the ColdFire Parts Forum. They are a 10 to 20 year old chip series that started as a RISC version of the MC68000 architecture.
The "LS1028AXE7KQA" is about as far removed from these parts as you can get, as it is a:
"Layerscape 64-bit Arm Cortex-A72, Dual-core, 1GHz, -40 to 105C, Security enabled, 3D GPU"
You should ask this question of your distributor or ask in the correct forum for that part, not here.
Nothing about this in the Data Sheet, is there?
Tom
