Coldfire MCF5208
Coldfire MCF5208
1,601 次查看
avinashnagumant
Hi i am using Lantronix Xport pro which uses Coldfire MCF5208. We are working on a new programming interface in which we had to cross compile to run the software on uclinux. Can you help me with the toolchain and their location of this specific hardware.
GCC Compiler, achiever, linker and flags required for cross build ?
1,471 次查看
miduo
For uClinux application & binary, please make reference from:
uClinux -- Embedded Linux/Microcontroller Project -- ColdFire: Binaries
B.R.
Fang
1,471 次查看
yibbidy
You get the linux hosted tools here:
http://www.lantronix.com/ftp/Linux_SDK/SDK2_0_0_3/linux_sdk_2_0_0_3.iso
There is an developer guide document in the iso which tells you everything you need to know to set up the development environment and compile/program/debug the XPort Pro.
Shaun
