CFFlasher command line problems
4,470 次查看
oed
Hello:
I'm trying to used cfflasher.exe from console, for automatizate the process to program my colfire.
But I don't know how to specify the velocity of the USB, when I use the cfflasher in windows change the speed of the usb to 10 or not works.
I have this command, only need how to set de speed:
$ cfflasher -t M52235EVB -p exampe.elf -s -bdm PE_USB_ML
Thanks!
1,797 次查看
oed
Or... another flasher program that can execute from command line? in windows.
Thanks!
PD: The idea is automatice the process to flash my mcf5213 in my eclipse IDE.
1,797 次查看
Nouchi
Senior Contributor II
You could use CPROGCFZ from P&E Micro, but it's not a free solution.
There was a linux BDM solution in the past for 68332, maybe you be inspired by this:
http://cmp.felk.cvut.cz/~pisa/
regards,
Emmanuel
