Assembler to C code
Assembler to C code
2,353 次查看
PabloA
Hi there, please could somebody help me with this code in Assembler? I have to translate it to C code. It works fine in CodeWarrior for 8 bits microcontrollers, but with ColdFire it don't acept this asm instructions.
The idea is to control an LCD display with just 4 bits of data. To do this I have to Swap Display 8 bits data and write the higher nible first.
char Display_Data;
char PTAD_Data;
  asm
    LDA   PTAD
    AND   #0b11110000     // Mask Non Display Data
    STA   PTAD_Data
    LDA   Display_Data    // Load Display Data
    NSA                        // Set Most Significant Nible First
    AND   #0b00001111     // Clear "Shift_Comp_Data" Bits
    ORA   PTAD_Data
    STA   PTAD            // Set Display Data
Thanks!
Pablo
2,003 次查看
kef
Specialist I
HI
   PTAD_Data = PTAD & 0xF0;
   PTAD = ((Display_Data >> 4) & 0x0F) | PTAD_Data;
2,004 次查看
kef
Specialist I
HI
2,003 次查看
PabloA
Edward, Thank you for your time. I will use it!
Best regards!
Pablo
