DMA Bus errors when reading from ADC
marksheahan
I am trying to read from the ADC at 500KHz, and store it in a buffer. Interrupts weren't fast enough, so I want to use DMA to move data from the ADC result registers into the buffer. There is a bus error on source when reading from the ADC result registers. What might be causing this?
The device is a MCF52235.
Thanks in advance,
Mark
marksheahan
Fixed, by setting master privilege register to include the DMA controller
maximevincent
Thank you so much for this!
Had to set PBRIDGE0.MPL2 = 1;
GREAT!
