Build at Optimization level O3 fails - Release configuration
2,235 次查看
ITCO00
I'm working with CW toolset 10.1.3 for SmartDSP MSC8156.
I've a 'C' compiled successfully at optimization O0, but at optimization level O3 it fails.
Preprocessing - produces the same text.
file size - ~17kb
Attached - verbose output  of the compilation process;
标记 (1)
1,542 次查看
CrasyCat
Specialist III
I would recommend you to submit a service request for that.
Click here to submit a service request.
Make sure to attach the preprocessing listing file and indicate which compiler options you are using for building.
CrasyCat
1,543 次查看
CrasyCat
Specialist III
CrasyCat
