undefined identifier 'pc'
2,517件の閲覧回数
litesrus
CodeWarrior IDE v5.9.0 build 2502
Target MCF5206e
Porting some assembly code that compiled under IDE v4.1.0.3.  In particular:
jmp  (pc,d2.l*2)
This causes a number of errors to be reported; the first of which is:
" undefined indentifier 'pc' "
???  pc is a valid 5206e register.
Any idea what might be wrong?
tom
タグ(1)
1,211件の閲覧回数
CrasyCat
Specialist III
Hello
I assume you are coding in inline assembler (not in an assembly source file).
Am I right?
Can you then try following notation:
       jmp  0(pc, d2.l*2)
CrasyCat
