U-boot NOR Flash
U-boot NOR Flash
vinothkumars
Senior Contributor IV
Hi All,
I am using T4240RDB-64B machine with codeWarrior Flashprogrammer V10.7.   And I got the following log when flash the u-boot. I want to give restricted address range for program.
How to find the flash start address and end address for u-boot to t4240rdb-64b machine.
Inline image
Flash Log:
l::target -lc "Peacock_10thDec-core00_RAM_T4160_Connect"
fl::target -b 0x0 0x100000
fl::target -v off -l off
cmdwin::fl::device -d "S29GL01GP" -o "128Mx8x1" -a 0xe8000000 0xefffffff
cmdwin::fl::erase all
Beginning Operation ...
Performing target initialization ...
Downloading Flash Device Driver ...
Reading flash ID ...
Erasing entire flash ...
Erasing ...
Erase Command Succeeded
fl::target -lc "Peacock_10thDec-core00_RAM_T4160_Connect"
Erasing ...
cmdwin::fl::image -f "C:\\Logi\\Work\\Projects\\BEL\\QorIQ_VPX\\Software\\T4160\\Zumi Solutions\\Uboot images\\181213\\u-boot-nor-2016.01+fslgit-r0.bin" -t "Auto Detect" -re off -oe on -o 0xe8000000
cmdwin::fl::erase image
Auto-detection is successful.
File is of type Binary/Raw Format.
Erasing Sector 0xE8000000 to 0xE801FFFF
Erasing Sector 0xE8020000 to 0xE803FFFF
Erasing Sector 0xE8040000 to 0xE805FFFF
Erasing Sector 0xE8060000 to 0xE807FFFF
Erasing Sector 0xE8080000 to 0xE809FFFF
Erasing Sector 0xE80A0000 to 0xE80BFFFF
Erasing ...
cmdwin::fl::write
Programming file C:\Logi\Work\Projects\BEL\QorIQ_VPX\Software\T4160\Zumi Solutions\Uboot images\181213\u-boot-nor-2016.01+fslgit-r
0.bin
Downloading 0x00010000 bytes to be programmed at 0xE8000000
Downloading 0x00010000 bytes to be programmed at 0xE8010000
Downloading 0x00010000 bytes to be programmed at 0xE8020000
Downloading 0x00010000 bytes to be programmed at 0xE8030000
Downloading 0x00010000 bytes to be programmed at 0xE8040000
Downloading 0x00010000 bytes to be programmed at 0xE8050000
Downloading 0x00010000 bytes to be programmed at 0xE8060000
Downloading 0x00010000 bytes to be programmed at 0xE8070000
Downloading 0x00010000 bytes to be programmed at 0xE8080000
Downloading 0x00010000 bytes to be programmed at 0xE8090000
Downloading 0x00010000 bytes to be programmed at 0xE80A0000
Downloading 0x00010000 bytes to be programmed at 0xE80B0000
Executing program ....
Executing program .....
Executing program ......
Executing program .......
Executing program ........
Executing program .........
Executing program ..........
Executing program ...........
Executing program ............
Executing program .............
Executing program ..............
Executing program ...............
Executing program ................
Executing program .................
Executing program ..................
Executing program ...................
Executing program ....................
Executing program .....................
Executing program ......................
Executing program .......................
Executing program ........................
Executing program .........................
Executing program ..........................
Executing program ...........................
Executing program ............................
Executing program .............................
Executing program ..............................
Executing program ...............................
Executing program ................................
Executing program .................................
Executing program ..................................
Executing program ...................................
Executing program ....................................
Executing program .....................................
Executing program ......................................
Executing program .......................................
Executing program ........................................
Executing program .........................................
Executing program ..........................................
Executing program ...........................................
Executing program ............................................
Executing program .............................................
Executing program ..............................................
Executing program ...............................................
Executing program ................................................
Executing program .................................................
Executing program ..................................................
Executing program ...................................................
Executing program ....................................................
Executing program .....................................................
Executing program ......................................................
Executing program .......................................................
Executing program ........................................................
Executing program .........................................................
Executing program ..........................................................
Executing program ...........................................................
Executing program ............................................................
Executing program .............................................................
Executing program ..............................................................
Thank you for all your support ....!
VinothS
Vinothkumar Sekar
Pavel
Look at the Table 110 of SDK 2.0 -1703 documentation:
https://www.nxp.com/docs/en/supporting-information/QORIQ-SDK-2.0-IC-REV0.pdf
This Table shows NOR Flash memory map for SDK 2.0.
Pavel Chubakov
vinothkumars
Hi Pavel,
Thank you for your response.
I followed table 110 for memory map and I used the "0xEFF40000 to 0xEFFFFFFF" for uboot erase and program action.
But, still I got Sector Protection Error.
Please give some more details to fix the following errors,
Error: Erase failed. Flash driver reports the following error(s): Sector Protection Error
Thanks & Regards,
VinothS
Vinothkumar Sekar
vinothkumars
Hi Pavel,
Any Update ?
Still I struggled in same place.
Regards, VinothS
Vinothkumar Sekar
monalihaware
Hi Vinothkumar,
I am using p2020 RDB and i got various errors while programming BIN file onto it. Additionally, it would say "program successful" in flash programmer but "0 bytes written".
Finally, what worked for me is following-
1. As it is RDB, i imported the xml file (in flash programmer-> task) for RDB from the installation path. As urs is T4240, import in 'task' the xml file from PA/bin/plugin/support/targettask/flashprogrammer/QorIQ_T4240/T2040RDB_NOR_Flash.xml. This wil automatically select the various options needed for the NOR on your RDB
2.In 'add  program/verifyaction' tab,give the path of the bin file
check 'erase sector before program'
check 'restrict to address in this range'  and give start and end address as start & end address of your NOR flash
check 'apply address offset' and give address as onto which location you want to burn the bin file. For Ex- my flash addr range is 0xff00_0000 - 0xffff_ffff.  so i gave this start( 0xff00_0000) and end(0xffff_ffff) address in 'restrict to address in this range' .  And i wanted to burn bin at "0xff04_0000' .
So i gave the ''apply address offset'  as  "0xff04_0000 "
3.Run the task
Actually, The following thread helped me and worked
https://community.nxp.com/thread/391994
Even i observed that if any slight mistake/mismatch in xml for the flash, the flash programmer wont be able to write/erase etc as per user's desire.
I hope this helps. But if it is your custom board then u need to work out on xml. I have not done it yet for custom board. i need to do that next.
vinothkumars
Hi Monali,
Thank you for your quick reply with detailed explanation.
Thanks & Regards,
VinothS
Vinothkumar Sekar
monalihaware
i hope it helps. It should if you using RDB
monalihaware
please let me know if it works. Though i have not gotten any error related to sector protection ever
vinothkumars
Hi Monali,
   I will reply once I done.
Thanks & Regards,
VinothS
Vinothkumar Sekar
vinothkumars
Hi Monali,
Do you have experience in DDR initialization using codewarrior or lauterbach?
If you done please provide the steps?
Regards, VinothS
Vinothkumar Sekar
monalihaware
No i dont have .sorry.
P2020 RM please download from fresscale. it is very huge to send.
Following is the content of P10xx-P20xxRDB_P2020_init_sram_flash.tcl:
proc envsetup {} {
# Environment Setup
radix x
config hexprefix 0x
config MemIdentifier v
config MemWidth 32
config MemAccess 32
config MemSwap off
# Main
envsetup
variable SPR_GROUP "e500 Special Purpose Registers/"
variable SSP_GROUP "Standard Special Purpose Registers/"
variable LA_GROUP "Local Access/"
variable ELBC_GROUP "Enhanced Local Bus Controller/"
variable CAM_GROUP "regPPCTLB1/"
variable GPR_GROUP "General Purpose Registers/"
variable LACCS_GROUP "Local-Access Registers-Configuration, Control, and Status Registers/"
variable L2_SRAM_GROUP "L2 Look-Aside Cache SRAM/"
# set interrupt vectors
# IVPR (compatible to the Flash)
reg ${SPR_GROUP}IVPR = 0xFFFF0000
# debug - (a valid instruction should exist to be fetched)
reg ${SPR_GROUP}IVOR15 = 0x0000F000
# program
reg ${SPR_GROUP}IVOR6 = 0x0000F700
# Set a breakpoint at the reset address
reg ${SPR_GROUP}IAC1 = 0xfffffffc
reg ${SPR_GROUP}DBCR0 = 0x40800000
reg ${SPR_GROUP}DBCR1 = 0x00000000
reg ${SSP_GROUP}MSR = 0x02000200
config runcontrolsync off
go
wait 50
config runcontrolsync on
stop
reg ${SPR_GROUP}DBCR0 = 0x41000000
reg ${SPR_GROUP}IAC1 = 0x00000000
# move CCSR at 0xE0000000
# CCSRBAR
# bit 8 - 23 - BASE_ADDR
variable CCSRBAR_addr [format %x [expr {[reg ${LACCS_GROUP}CCSRBAR %x] << 12 }]]
mem p:$CCSRBAR_addr = 0x000e0000
# invalidate BR0
reg ${ELBC_GROUP}BR0 = 0x00001000
# ABIST off
# L2ERRDIS[MBECCDIS]=1 L2ERRDIS[SBECCDIS]=1
reg ${L2_SRAM_GROUP}L2ERRDIS = 0x0000000C
# activate debug interrupt and enable SPU
# Memory Map
# 0x00000000 0x0003FFFF SRAM 256K
# 0xE0000000 0xE00FFFFF CCSRBAR Space 1M
# 0xF8000000 0xF80FFFFF LocalBus NAND FLASH 1M
# 0xFF000000 0xFFFFFFFF LocalBus NOR FLASH 16M
# MMU initialization
# define 1MB TLB1 entry 1: 0xE0000000 - 0xE00FFFFF; for CCSR Space, non cacheable
reg ${CAM_GROUP}L2MMU_CAM1 = 0x500003CAFC080000E0000000E0000001
# define 16MB TLB1 entry 2: 0xFF000000 - 0xFFFFFFFF; for Local Bus, cache inhibited
reg ${CAM_GROUP}L2MMU_CAM2 = 0x70000FCAFC080000FF000000FF000001
# define 256KB TLB1 entry 3: 0x00000000 - 0x0003FFFF; for internal chip SRAM
reg ${CAM_GROUP}L2MMU_CAM3 = 0x400001C0FC0800000000000000000001
# define 1MB TLB1 entry 7: 0xF8000000 - 0xF80FFFFF; for NAND, cache inhibited
reg ${CAM_GROUP}L2MMU_CAM7 = 0x500003CAFC080000F8000000F8000001
# disable Boot Page Translation Register
reg ${LACCS_GROUP}BPTR = 0x00000000
# Invalidate again BR0 to prevent flash data damage in case
# the boot sequencer re-enables CS0 access
# configure internal SRAM at 0x00000000
# L2CTL
# bit 0 = 0 - L2E: L2 SRAM disabled
# bit 2-3 = 10 - L2SIZ: = 512K
# bit 13-15 = 010 - L2SRAM: One half is SRAM (256K)
reg ${L2_SRAM_GROUP}L2CTL = 0x20020000
# L2SRBAR0
# bit 0-17 = BASE addr: 0x00000000
reg ${L2_SRAM_GROUP}L2SRBAR0 = 0x00000000
# L2SRBAREA0
# bit 28-31 = EXTENTED BASE addr: 0x00000000
reg ${L2_SRAM_GROUP}L2SRBAREA0 = 0x00000000
# L2CTL
# bit 0 = 1 - L2E: L2 SRAM enable
reg ${L2_SRAM_GROUP}L2CTL = 0xA0020000
# Memory Windows
# 0xFF000000 0xFFFFFFFF LAW0 Local Bus NOR FLASH - 16M
# 0xF8000000 0xF80FFFFF LAW5 Local Bus NAND FLASH 1M
# configure local access windows
# LAWBAR0 - Local Bus
# bit 8 - 31 = 0xFF000000 - base addr
reg ${LA_GROUP}LAWBAR0 = 0x000ff000
# LAWAR0
# bit 0 = 1 - enable window
# bit 7-11 = 00100 - Local Bus
# bit 26 - 31 = 011011 16M - size
reg ${LA_GROUP}LAWAR0 = 0x80400017
# LAWBAR5 - Local Bus
# bit 8 - 31 = 0xF8000000 - base addr
reg ${LA_GROUP}LAWBAR5 = 0x000f8000
# LAWAR5
# bit 26-31 = 010011 1M - size
reg ${LA_GROUP}LAWAR5 = 0x80400013
# configure Local Bus memory controller
# CS0 - Flash
# BR0 base address at 0xF8000000, port size 16 bit, GPCM, valid
reg ${ELBC_GROUP}BR0 = 0xFF001001
# OR0 16MB flash size
reg ${ELBC_GROUP}OR0_GPCM = 0xFF000FF7
# CS1 - NAND Flash
# BR1 base address at 0xF8000000, port size 8 bit, FCM, valid
reg ${ELBC_GROUP}BR1 = 0xF8000C21
# OR1 1MB size
reg ${ELBC_GROUP}OR1_GPCM = 0xFFF80396
# LBCR
reg ${ELBC_GROUP}LBCR = 0x40000000
# LCRR
reg ${ELBC_GROUP}LCRR = 0x80000008
# interrupt vectors initialization
# interrupt vectors in internal SRAM
# IVPR (default reset value)
reg ${SPR_GROUP}IVPR = 0x00000000
# interrupt vector offset registers
# IVOR0 - critical input
reg ${SPR_GROUP}IVOR0 = 0x00000100
# IVOR1 - machine check
reg ${SPR_GROUP}IVOR1 = 0x00000200
# IVOR2 - data storage
reg ${SPR_GROUP}IVOR2 = 0x00000300
# IVOR3 - instruction storage
reg ${SPR_GROUP}IVOR3 = 0x00000400
# IVOR4 - external input
reg ${SPR_GROUP}IVOR4 = 0x00000500
# IVOR5 - alignment
reg ${SPR_GROUP}IVOR5 = 0x00000600
# IVOR6 - program
reg ${SPR_GROUP}IVOR6 = 0x00000700
# IVOR8 - system call
reg ${SPR_GROUP}IVOR8 = 0x00000c00
# IVOR10 - decrementer
reg ${SPR_GROUP}IVOR10 = 0x00000900
# IVOR11 - fixed-interval timer interrupt
reg ${SPR_GROUP}IVOR11 = 0x00000f00
# IVOR12 - watchdog timer interrupt
reg ${SPR_GROUP}IVOR12 = 0x00000b00
# IVOR13 - data TLB errror
reg ${SPR_GROUP}IVOR13 = 0x00001100
# IVOR14 - instruction TLB error
reg ${SPR_GROUP}IVOR14 = 0x00001000
# IVOR15 - debug
reg ${SPR_GROUP}IVOR15 = 0x00001500
# IVOR32 - SPE-APU unavailable
reg ${SPR_GROUP}IVOR32 = 0x00001600
# IVOR33 - SPE-floating point data exception
reg ${SPR_GROUP}IVOR33 = 0x00001700
# IVOR34 - SPE-floating point round exception
reg ${SPR_GROUP}IVOR34 = 0x00001800
# IVOR35 - performance monitor
reg ${SPR_GROUP}IVOR35 = 0x00001900
# put a valid opcode at debug and progrm exception vector address
mem v:0x00000700 = 0x48000000
mem v:0x00001500 = 0x48000000
# time base enable
# HID0
reg ${SPR_GROUP}HID0 = 0x00004000
# NAND Flash settings
# FMR
reg ${ELBC_GROUP}FMR = 0x0000F020
# CW debugger settings
#Trap debug event enable
# set the PC at the reset address (for debug-->connect)
reg ${GPR_GROUP}PC = 0xFFFFFFFC
# for debugging starting at program entry point when stack is not initialized
reg ${GPR_GROUP}SP = 0x0000000F
vinothkumars
Hi Monali,
Thank you.
Vinothkumar Sekar
monalihaware
Hi Vinothkumar,
Do u have any docs of preboot loader and what it actually does. And what happens after the control comes to 0xfffffffc after reset?
vinothkumars
Hi Monali,
Now I am trying through lauterbach trace32 debugger.  I will update once I done through codewarrior.
Vinothkumar Sekar
vinothkumars
Hi All,
From s29GL01GS datasheet, Flash Chip: S29GL01GS  and Device ID: 227E
From CodeWarrior IDE, Flash Chip Driver: S29GL01GP and Organization : 64MX16X1
From S29GL01GP.XML,
    Sector Protection Error will appear using this 64MX16X1 Organization.
    But, When use the 128MX8X1 Organization, There is no error but, program execute continuously.
    Difference between these two Orgainzation is flash algorithm.
Inline image
Inline image
Console View,
fl::target -b 0x0 0x20000
cmdwin::fl::device -d "S29GL01GP" -o "64Mx16x1" -a 0xe8000000 0xefffffff
cmdwin::fl::protect all off
Downloading Flash Diagnostics Driver ...
Unprotecting all sectors...
Unprotecting ...
Unprotecting ....
Unprotecting .....
Unprotecting ......
Unprotecting .......
Unprotecting ........
Unprotecting .........
Unprotect Command Succeeded
Erasing ...
Thank you for everyone help....!
VinothS
Vinothkumar Sekar
vinothkumars
Hi All,
What is the difference between S29GL01GS and S29GL512S Flash Device ?
I am using S29GL01GS and I select Organization as 64MX16X1.
or
I Want to Select  Organization as 128MX8X1.
Which one I want to select to program using CodeWarrior Flashprogrammer?
Thank you for all your support........!
Regards, VinothS
Vinothkumar Sekar
vinothkumars
Hi All,
Still I am struggled with the organization selection for S29GL01GS
And I followed this datasheet,
http://www.cypress.com/file/177976/download
From that which Organization want to select for CodeWarrior Flashprogrammer.
Thank for all your support.......!
Regards, VinothS
Vinothkumar Sekar
