QCVS install failure
4,728 次查看
zhicheng1
I try to intall QCVS, but always show below error. I have tried other update site for installing QCVS + FSL Updater is http://freescale.com/lgfiles/updates/Eclipse/QCVS for only ARM support or http://freescale.com/lgfiles/updates/Eclipse/QCVS_PA​ for QCVS 4.5 release including ARM + PA support. But it still fail.
Could you tell me what to do next?
Error:
CW Version:
4,713 次查看
zhicheng1
there is a error when download  CodeWarrior for Power Architectures Rev 4.5 from  https://support.nxp.com/s/case/5002p00002xWCo9AAG/community-qcvs-install-failure?language=en_US
the error log:
Unable to Finish Processing Request
An error has occurred while processing your request. The salesforce.com support team has been notified of the problem. If you believe you have additional information that may be of help in reproducing or correcting the error, please contact [email protected]. Please indicate the URL of the page you were requesting as well as any other related information. We apologize for the inconvenience.
Thank you again for your patience and assistance. And thanks for using salesforce.com!
Error ID: Data Not Available
6 回复数
4,707 次查看
zhicheng1
please ignore this download error. I have found CodeWarrior for Power Architectures Rev 4.5 on NXP website. Thank you!
4,719 次查看
yipingwang
Please download QCVS for PA 4.5 offline installation package from https://support.nxp.com/s/case/5002p00002xWCo9AAG/community-qcvs-install-failure?language=en_US
Then open CodeWarrior IDE and install QCVS for PA 4.5 from Help->Install New Software->Add->Archive.
4,236 次查看
pipi95
Can't down from this link, give an error page.
4,233 次查看
pipi95
@yipingwangexpect for your response, Thanks very much!
4,186 次查看
pipi95
I have already got one, no need any more thanks!
4,714 次查看
zhicheng1
the error log:
