No probe connection for Codewarrior Tap
2,871 次查看
cengizhanyapici
In my bareboard application I want to use Codewarrior development studio although when I create a new project and debug it I take an error which is "CCSProtocolPlugin:Could not connect to the probe(or other debug link)
[CCS last error:CC not present ]"
Then,I run the necessary COM port from TerraTerm application and I see "No probe connection" message on the screen.Is the problem related to this "No probe connection" message which is given as attached? or Is there some problem about CodeWarrior's connections? Thanks for your answers.
Best Ragards
2,567 次查看
addiyi
What connection you are setting in CW for cwtap?
Adrian
