Medical USB compiling issues under CW V10
2,004 次查看
admin
Specialist II
Anyone successfully compile and run the Medical USB demo on a Flexis JM demonstration board (DEMOJM) using Code Warrior V10?
I am trying but I am getting too many errors that I don't understand.
Examples:
Description Resource Path Location Type
illegal implicit conversion from 'struct  *' to 'unsigned char *' khci.c Host_HID_example/User_Files/Source line 653 C/C++ Problem
illegal implicit conversion from 'struct  *' to 'int *' khci.c Host_HID_example/User_Files/Source line 554 C/C++ Problem
I am also coming up with a bunch of warnings:
implicit arithmetic conversion from 'int' to 'unsigned long' khci.c Host_HID_example/User_Files/Source line 262 C/C++ Problem
implicit arithmetic conversion from 'long' to 'unsigned short' khci.c Host_HID_example/User_Files/Source line 354 C/C++ Problem
I am new to using CW tools and it's been a while since I was coding, so I may be making a novice mistake in the setup.  Any suggestions are welcomed.
标记 (1)
1,443 次查看
admin
Specialist II
1,444 次查看
admin
Specialist II
