Kernel Aware Debug
Kernel Aware Debug
4,711 次查看
dferbas
does anyone know if a sample kernel aware debug plugin exists ? I mean a package where I should implement only APIs described in Kernel-Aware_Debug_API.pdf and all other things (code skeleton with loading symbols from .elf, communication with target board over BDM) are already prepared ?
Dusan
标记 (1)
2,431 次查看
CompilerGuru
Hi Dusan,
Well, where do you have the Kernel-AwarePluginManual.pdf from? I would check the same souce for samples as well.
To my knowledge the CodeWarrior COM Kernel Aware debugger API was only delivered to certain 3'rd parties and was never publicly available.
2,430 次查看
dferbas
this .pdf can be found among other manuals with every ColdFire CodeWarrior IDE. There is also .chm file. In the past I ported MetroTRK onto MC68EN302 for our OS. So I think I am expertized enough to do such a job. It's a pitty that such a plugin is not publicly available. Can we buy it ?
Dusan
