CodeWarrior debugging??
2,147 次查看
ck_max
I got a problem running MQX HVAC demo(52259).
I followed steps described in M52259DEMOKIT quick start guide, but the debugger stopped when I press 'RUN' in step 3.
I can trace into codes using 'Step Over' or 'Stop Into', but debugger stopped when pressing 'Run'.
Anyone know what's the problem?
Max.
标记 (1)
1,419 次查看
ck_max
Sorry, I should describe more clearly.
I followed the instructions in document 'Freescale MQX RTOS USB TCPIP Lab Tutorials for MCF52259 MCF52235 MCF52223'.
It's no problem from step 1 to 12, but when I follow step 13 to press 'Debug' button again, the program stopped as bitmap above.
 What's wrong?
By the way, I'm not using M52259DEMOKIT, cause it's out of stock until Feb 5th next year.
I'm waiting for one and half month, and there still 2 and half months I shell wait. Orz
Our hardware engineer already created several boards nearly the same with demokit, and I used them for testing.
And I use P&E USB Multi-link for programming and debugging.
Max.
