CodeWarrior IDE Editor
4,092件の閲覧回数
akaustav
I am using CodeWarrior IDE for Microcontrollers v6.2 with v6.2.1 compiler patch. I write programs using C/C++. I want to know if there is a way to:
1. configure the editor not to go beyond the end-of-line character.
2. show tabs and whitespaces in the editor.
Ameet Kaustav
タグ(1)
2,713件の閲覧回数
RichTestardi
Senior Contributor II
If I understand the question, I believe you want to uncheck:
  Edit -> Preferences... -> Editor -> Editor Settings -> "Enable Virtual Space"
-- Rich
3 返答(返信)
2,713件の閲覧回数
RichTestardi
-- Rich
2,713件の閲覧回数
akaustav
Thank you for your reply, Rich. Yup, you understood the question and the solution works. Thank you. Here are my follow-up questions:
1. Is there a document which lists all the consequences of the settings in these IDE Preferences panel? (I mean I would like to know what "Virtual Space" means.)
2. By any chance, do you know the answer to the question no. 2 of my previous post?
Ameet Kaustav
2,713件の閲覧回数
akaustav
I got the answer to question no. 1. These editor features are mentioned in the Editor secion of CodeWarrior™ Development Studio 8/16-Bit IDE User’s Guide (CW816BITIDEUG.pdf) document for CodeWarrior V6.2.
