Code Warrior Installation Problem (for Ubuntu 14.04)
5,682件の閲覧回数
victormazin
I tried to install CodeWarrior for QorIQ LS Series ARMv7 ISA Linux v10.0.7  (evaluation version)- Offline to Ubuntu 14.04 (LTS, x64).
However I Received a lot of errors during the installation of the dependencies. Please see below.
How can I install the CodeWarrior?
I followed the instructions: I downloaded the file (CodeWarrior for QorIQ LS Series ARMv7 ISA Linux v10.0.7 - Offline.tar) from Freescale website, extracted the TAR file, opened the new terminal window in the disk1 directory and started   ./setuplinux command.
However I got the followed message:
The dependencies could not be automatically installed. Please try to manually install the following dependencies and then restart the installer:
libc6:i386
libgcc1:i386
gcc-4.6-base:i386
libstdc++5:i386
libstdc++6:i386
libgtk2.0-0:i386
I attempted to install the dependencies manually as it mentioned in the README file (paragraph 2.13 Ubuntu 13.10 /14.04):
# sudo sed -i -re 's/([a-z]{2}\.)?archive.ubuntu.com|security.ubuntu.com/old-releases.ubuntu.com/g' /etc/apt/sources.list
# sudo apt-get update
# sudo apt-get install libc6:i386 libgcc1:i386 gcc-4.6-base:i386 libstdc++5:i386 libstdc++6:i386 libgtk2.0-0:i386 libxpm4:i386 libusb-0.1-4:i386 libusb-1.0-0:i386 libuuid1:i386 libxcb1:i386 libnspr4:i386 libglib2.0-0:i386 libxdamage1:i386 libxtst6:i386 libssl0.9.8:i386
However I received the list of errors:
E: Package 'libc6:i386' has no installation candidate
E: Package 'libgcc1:i386' has no installation candidate
E: Unable to locate package gcc-4.6-base
E: Couldn't find any package by regex 'gcc-4.6-base'
E: Unable to locate package libstdc++5
E: Couldn't find any package by regex 'libstdc++5'
E: Package 'libstdc++6:i386' has no installation candidate
E: Package 'libgtk2.0-0:i386' has no installation candidate
E: Unable to locate package libxpm4
E: Unable to locate package libusb-0.1-4
E: Couldn't find any package by regex 'libusb-0.1-4'
E: Unable to locate package libusb-1.0-0
E: Couldn't find any package by regex 'libusb-1.0-0'
E: Package 'libuuid1:i386' has no installation candidate
E: Unable to locate package libxcb1
E: Package 'libnspr4:i386' has no installation candidate
E: Package 'libglib2.0-0:i386' has no installation candidate
E: Package 'libxdamage1:i386' has no installation candidate
E: Package 'libxtst6:i386' has no installation candidate
E: Unable to locate package libssl0.9.8
E: Couldn't find any package by regex 'libssl0.9.8'
Regards Victor
4,636件の閲覧回数
lunminliang
Hello Victor Mazin,
I tried on my Ubuntu 14.04 64bit, it prints message that CodeWarrior dependency will not be automatically installed, after a while when I was checking the dependency the installation go on and success.
This seems to be related with source. Attached is my sources.list.
5 返答(返信)
4,637件の閲覧回数
lunminliang
Hello Victor Mazin,
4,636件の閲覧回数
addiyi
Hi Victor,
Could you please provide also the log when run # sudo apt-get update
Adrian
4,636件の閲覧回数
victormazin
Hi Adrian,
Thank you for the answer.
Please see the log below.
Victor
ustinco@ustinco-Inspiron-530s:~/Documents/Belfast/Warrior/disk1$ sudo apt-get update
Ign http://dl.google.com stable InRelease
Hit http://dl.google.com stable Release.gpg
Ign http://extras.ubuntu.com trusty InRelease
Ign http://old-releases.ubuntu.com trusty InRelease
Hit http://dl.google.com stable/main amd64 Packages
Hit http://extras.ubuntu.com trusty Release.gpg
Ign http://old-releases.ubuntu.com trusty-updates InRelease
Hit http://dl.google.com stable/main i386 Packages
Hit http://repos.codelite.org trusty InRelease
Ign http://old-releases.ubuntu.com trusty-backports InRelease
Ign http://old-releases.ubuntu.com trusty-security InRelease
Hit http://extras.ubuntu.com trusty/main Sources
Hit http://repos.codelite.org trusty/universe amd64 Packages
Ign http://old-releases.ubuntu.com trusty Release.gpg
Hit http://extras.ubuntu.com trusty/main amd64 Packages
Hit http://repos.codelite.org trusty/universe i386 Packages
Ign http://old-releases.ubuntu.com trusty-updates Release.gpg
Hit http://extras.ubuntu.com trusty/main i386 Packages
Ign http://old-releases.ubuntu.com trusty-backports Release.gpg
Ign http://dl.google.com stable/main Translation-en_CA
Ign http://old-releases.ubuntu.com trusty-security Release.gpg
Ign http://extras.ubuntu.com trusty/main Translation-en_CA
Ign http://repos.codelite.org trusty/universe Translation-en_CA
Err http://old-releases.ubuntu.com trusty/main Sources
  404  Not Found
Err http://old-releases.ubuntu.com trusty/restricted Sources
  404  Not Found
Err http://old-releases.ubuntu.com trusty/universe Sources
  404  Not Found
Err http://old-releases.ubuntu.com trusty/multiverse Sources
  404  Not Found
Err http://old-releases.ubuntu.com trusty/main amd64 Packages
  404  Not Found
Err http://old-releases.ubuntu.com trusty/restricted amd64 Packages
  404  Not Found
Err http://old-releases.ubuntu.com trusty/universe amd64 Packages
  404  Not Found
Err http://old-releases.ubuntu.com trusty/multiverse amd64 Packages
  404  Not Found
Err http://old-releases.ubuntu.com trusty/main i386 Packages
  404  Not Found
Err http://old-releases.ubuntu.com trusty/restricted i386 Packages
  404  Not Found
Err http://old-releases.ubuntu.com trusty/universe i386 Packages
  404  Not Found
Err http://old-releases.ubuntu.com trusty/multiverse i386 Packages
  404  Not Found
Ign http://old-releases.ubuntu.com trusty/main Translation-en_CA
Ign http://old-releases.ubuntu.com trusty/multiverse Translation-en_CA
Ign http://old-releases.ubuntu.com trusty/restricted Translation-en_CA
Ign http://old-releases.ubuntu.com trusty/universe Translation-en_CA
Err http://old-releases.ubuntu.com trusty-updates/main Sources
  404  Not Found
Err http://old-releases.ubuntu.com trusty-updates/restricted Sources
  404  Not Found
Err http://old-releases.ubuntu.com trusty-updates/universe Sources
  404  Not Found
Err http://old-releases.ubuntu.com trusty-updates/multiverse Sources
  404  Not Found
Err http://old-releases.ubuntu.com trusty-updates/main amd64 Packages
  404  Not Found
Err http://old-releases.ubuntu.com trusty-updates/restricted amd64 Packages
  404  Not Found
Err http://old-releases.ubuntu.com trusty-updates/universe amd64 Packages
  404  Not Found
Err http://old-releases.ubuntu.com trusty-updates/multiverse amd64 Packages
  404  Not Found
Err http://old-releases.ubuntu.com trusty-updates/main i386 Packages
  404  Not Found
Err http://old-releases.ubuntu.com trusty-updates/restricted i386 Packages
  404  Not Found
Err http://old-releases.ubuntu.com trusty-updates/universe i386 Packages
  404  Not Found
Err http://old-releases.ubuntu.com trusty-updates/multiverse i386 Packages
  404  Not Found
Ign http://old-releases.ubuntu.com trusty-updates/main Translation-en_CA
Ign http://old-releases.ubuntu.com trusty-updates/multiverse Translation-en_CA
Ign http://old-releases.ubuntu.com trusty-updates/restricted Translation-en_CA
Ign http://old-releases.ubuntu.com trusty-updates/universe Translation-en_CA
Err http://old-releases.ubuntu.com trusty-backports/main Sources
  404  Not Found
Err http://old-releases.ubuntu.com trusty-backports/restricted Sources
  404  Not Found
Err http://old-releases.ubuntu.com trusty-backports/universe Sources
  404  Not Found
Err http://old-releases.ubuntu.com trusty-backports/multiverse Sources
  404  Not Found
Err http://old-releases.ubuntu.com trusty-backports/main amd64 Packages
  404  Not Found
Err http://old-releases.ubuntu.com trusty-backports/restricted amd64 Packages
  404  Not Found
Err http://old-releases.ubuntu.com trusty-backports/universe amd64 Packages
  404  Not Found
Err http://old-releases.ubuntu.com trusty-backports/multiverse amd64 Packages
  404  Not Found
Err http://old-releases.ubuntu.com trusty-backports/main i386 Packages
  404  Not Found
Err http://old-releases.ubuntu.com trusty-backports/restricted i386 Packages
  404  Not Found
Err http://old-releases.ubuntu.com trusty-backports/universe i386 Packages
  404  Not Found
Err http://old-releases.ubuntu.com trusty-backports/multiverse i386 Packages
  404  Not Found
Ign http://old-releases.ubuntu.com trusty-backports/main Translation-en_CA
Ign http://old-releases.ubuntu.com trusty-backports/multiverse Translation-en_CA
Ign http://old-releases.ubuntu.com trusty-backports/restricted Translation-en_CA
Ign http://old-releases.ubuntu.com trusty-backports/universe Translation-en_CA
Err http://old-releases.ubuntu.com trusty-security/main Sources
  404  Not Found
Err http://old-releases.ubuntu.com trusty-security/restricted Sources
  404  Not Found
Err http://old-releases.ubuntu.com trusty-security/universe Sources
  404  Not Found
Err http://old-releases.ubuntu.com trusty-security/multiverse Sources
  404  Not Found
Err http://old-releases.ubuntu.com trusty-security/main amd64 Packages
  404  Not Found
Err http://old-releases.ubuntu.com trusty-security/restricted amd64 Packages
  404  Not Found
Err http://old-releases.ubuntu.com trusty-security/universe amd64 Packages
  404  Not Found
Err http://old-releases.ubuntu.com trusty-security/multiverse amd64 Packages
  404  Not Found
Err http://old-releases.ubuntu.com trusty-security/main i386 Packages
  404  Not Found
Err http://old-releases.ubuntu.com trusty-security/restricted i386 Packages
  404  Not Found
Err http://old-releases.ubuntu.com trusty-security/universe i386 Packages
  404  Not Found
Err http://old-releases.ubuntu.com trusty-security/multiverse i386 Packages
  404  Not Found
Ign http://old-releases.ubuntu.com trusty-security/main Translation-en_CA
Ign http://old-releases.ubuntu.com trusty-security/multiverse Translation-en_CA
Ign http://old-releases.ubuntu.com trusty-security/restricted Translation-en_CA
Ign http://old-releases.ubuntu.com trusty-security/universe Translation-en_CA
W: Failed to fetch http://old-releases.ubuntu.com/ubuntu/dists/trusty/main/source/Sources  404  Not Found
W: Failed to fetch http://old-releases.ubuntu.com/ubuntu/dists/trusty/restricted/source/Sources  404  Not Found
W: Failed to fetch http://old-releases.ubuntu.com/ubuntu/dists/trusty/universe/source/Sources  404  Not Found
W: Failed to fetch http://old-releases.ubuntu.com/ubuntu/dists/trusty/multiverse/source/Sources  404  Not Found
W: Failed to fetch http://old-releases.ubuntu.com/ubuntu/dists/trusty/main/binary-amd64/Packages  404  Not Found
W: Failed to fetch http://old-releases.ubuntu.com/ubuntu/dists/trusty/restricted/binary-amd64/Packages  404  Not Found
W: Failed to fetch http://old-releases.ubuntu.com/ubuntu/dists/trusty/universe/binary-amd64/Packages  404  Not Found
W: Failed to fetch http://old-releases.ubuntu.com/ubuntu/dists/trusty/multiverse/binary-amd64/Packages  404  Not Found
W: Failed to fetch http://old-releases.ubuntu.com/ubuntu/dists/trusty/main/binary-i386/Packages  404  Not Found
W: Failed to fetch http://old-releases.ubuntu.com/ubuntu/dists/trusty/restricted/binary-i386/Packages  404  Not Found
W: Failed to fetch http://old-releases.ubuntu.com/ubuntu/dists/trusty/universe/binary-i386/Packages  404  Not Found
W: Failed to fetch http://old-releases.ubuntu.com/ubuntu/dists/trusty/multiverse/binary-i386/Packages  404  Not Found
W: Failed to fetch http://old-releases.ubuntu.com/ubuntu/dists/trusty-updates/main/source/Sources  404  Not Found
W: Failed to fetch http://old-releases.ubuntu.com/ubuntu/dists/trusty-updates/restricted/source/Sources  404  Not Found
W: Failed to fetch http://old-releases.ubuntu.com/ubuntu/dists/trusty-updates/universe/source/Sources  404  Not Found
W: Failed to fetch http://old-releases.ubuntu.com/ubuntu/dists/trusty-updates/multiverse/source/Sources  404  Not Found
W: Failed to fetch http://old-releases.ubuntu.com/ubuntu/dists/trusty-updates/main/binary-amd64/Packages  404  Not Found
W: Failed to fetch http://old-releases.ubuntu.com/ubuntu/dists/trusty-updates/restricted/binary-amd64/Packages  404  Not Found
W: Failed to fetch http://old-releases.ubuntu.com/ubuntu/dists/trusty-updates/universe/binary-amd64/Packages  404  Not Found
W: Failed to fetch http://old-releases.ubuntu.com/ubuntu/dists/trusty-updates/multiverse/binary-amd64/Packages  404  Not Found
W: Failed to fetch http://old-releases.ubuntu.com/ubuntu/dists/trusty-updates/main/binary-i386/Packages  404  Not Found
W: Failed to fetch http://old-releases.ubuntu.com/ubuntu/dists/trusty-updates/restricted/binary-i386/Packages  404  Not Found
W: Failed to fetch http://old-releases.ubuntu.com/ubuntu/dists/trusty-updates/universe/binary-i386/Packages  404  Not Found
W: Failed to fetch http://old-releases.ubuntu.com/ubuntu/dists/trusty-updates/multiverse/binary-i386/Packages  404  Not Found
W: Failed to fetch http://old-releases.ubuntu.com/ubuntu/dists/trusty-backports/main/source/Sources  404  Not Found
W: Failed to fetch http://old-releases.ubuntu.com/ubuntu/dists/trusty-backports/restricted/source/Sources  404  Not Found
W: Failed to fetch http://old-releases.ubuntu.com/ubuntu/dists/trusty-backports/universe/source/Sources  404  Not Found
W: Failed to fetch http://old-releases.ubuntu.com/ubuntu/dists/trusty-backports/multiverse/source/Sources  404  Not Found
W: Failed to fetch http://old-releases.ubuntu.com/ubuntu/dists/trusty-backports/main/binary-amd64/Packages  404  Not Found
W: Failed to fetch http://old-releases.ubuntu.com/ubuntu/dists/trusty-backports/restricted/binary-amd64/Packages  404  Not Found
W: Failed to fetch http://old-releases.ubuntu.com/ubuntu/dists/trusty-backports/universe/binary-amd64/Packages  404  Not Found
W: Failed to fetch http://old-releases.ubuntu.com/ubuntu/dists/trusty-backports/multiverse/binary-amd64/Packages  404  Not Found
W: Failed to fetch http://old-releases.ubuntu.com/ubuntu/dists/trusty-backports/main/binary-i386/Packages  404  Not Found
W: Failed to fetch http://old-releases.ubuntu.com/ubuntu/dists/trusty-backports/restricted/binary-i386/Packages  404  Not Found
W: Failed to fetch http://old-releases.ubuntu.com/ubuntu/dists/trusty-backports/universe/binary-i386/Packages  404  Not Found
W: Failed to fetch http://old-releases.ubuntu.com/ubuntu/dists/trusty-backports/multiverse/binary-i386/Packages  404  Not Found
W: Failed to fetch http://old-releases.ubuntu.com/ubuntu/dists/trusty-security/main/source/Sources  404  Not Found
W: Failed to fetch http://old-releases.ubuntu.com/ubuntu/dists/trusty-security/restricted/source/Sources  404  Not Found
W: Failed to fetch http://old-releases.ubuntu.com/ubuntu/dists/trusty-security/universe/source/Sources  404  Not Found
W: Failed to fetch http://old-releases.ubuntu.com/ubuntu/dists/trusty-security/multiverse/source/Sources  404  Not Found
W: Failed to fetch http://old-releases.ubuntu.com/ubuntu/dists/trusty-security/main/binary-amd64/Packages  404  Not Found
W: Failed to fetch http://old-releases.ubuntu.com/ubuntu/dists/trusty-security/restricted/binary-amd64/Packages  404  Not Found
W: Failed to fetch http://old-releases.ubuntu.com/ubuntu/dists/trusty-security/universe/binary-amd64/Packages  404  Not Found
W: Failed to fetch http://old-releases.ubuntu.com/ubuntu/dists/trusty-security/multiverse/binary-amd64/Packages  404  Not Found
W: Failed to fetch http://old-releases.ubuntu.com/ubuntu/dists/trusty-security/main/binary-i386/Packages  404  Not Found
W: Failed to fetch http://old-releases.ubuntu.com/ubuntu/dists/trusty-security/restricted/binary-i386/Packages  404  Not Found
W: Failed to fetch http://old-releases.ubuntu.com/ubuntu/dists/trusty-security/universe/binary-i386/Packages  404  Not Found
W: Failed to fetch http://old-releases.ubuntu.com/ubuntu/dists/trusty-security/multiverse/binary-i386/Packages  404  Not Found
E: Some index files failed to download. They have been ignored, or old ones used instead.
4,636件の閲覧回数
addiyi
Ubuntu 14.04 is LTS, so repo for old releases should be available. But, on your Ubuntu, you get some Not Found errors. Please take a look on this link​, seems to resolved this kind of issues.
Adrian
4,636件の閲覧回数
victormazin
Hi Adrian ,
Thank you for your answer.
The link which you mentioned did not help. Their recommendation "sudo rm /var/lib/apt/lists/* -vf" did not solve the problem.
I unchecked the other software in the Software Updates.Please see the picture below:
Next I tried to install CodeWarrior again. However the installation was not successful. Please the log below.
Could you give more recomendation regarding CodeWarrior installation?
Victor
ustinco@ustinco-Inspiron-530s:~/Documents/Belfast/CW2/disk1$ ls
md5sums  output.txt  README.txt  runinstall.572.dat  runinstall.574.dat  runinstall.876.dat  runinstall.955.dat  runinstall.sh  setuplinux  updates.xml
ustinco@ustinco-Inspiron-530s:~/Documents/Belfast/CW2/disk1$ ./setuplinux
libc6:i386
libgcc1:i386
gcc-4.6-base:i386
libstdc++5:i386
libstdc++6:i386
libgtk2.0-0:i386
Press any key to continue...
ustinco@ustinco-Inspiron-530s:~/Documents/Belfast/CW2/disk1$ sudo sed -i -re 's/([a-z]{2}\.)?archive.ubuntu.com|security.ubuntu.com/old-releases.ubuntu.com/g' /etc/apt/sources.list
[sudo] password for ustinco:
ustinco@ustinco-Inspiron-530s:~/Documents/Belfast/CW2/disk1$ sudo apt-get update
Reading package lists... Done
ustinco@ustinco-Inspiron-530s:~/Documents/Belfast/CW2/disk1$ sudo apt-get install libc6:i386 libgcc1:i386 gcc-4.6-base:i386 libstdc++5:i386 libstdc++6:i386 libgtk2.0-0:i386 libxpm4:i386 libusb-0.1-4:i386 libusb-1.0-0:i386 libuuid1:i386 libxcb1:i386 libnspr4:i386 libglib2.0-0:i386 libxdamage1:i386 libxtst6:i386 libssl0.9.8:i386
Building dependency tree
Reading state information... Done
Package libc6:i386 is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
However, the following packages replace it:
  libc-bin initscripts locales tzdata
Package libgcc1:i386 is not available, but is referred to by another package.
Package libglib2.0-0:i386 is not available, but is referred to by another package.
  libglib2.0-bin
Package libgtk2.0-0:i386 is not available, but is referred to by another package.
  libgtk2.0-common libgdk-pixbuf2.0-0
Package libstdc++6:i386 is not available, but is referred to by another package.
Package libnspr4:i386 is not available, but is referred to by another package.
Package libxdamage1:i386 is not available, but is referred to by another package.
Package libxtst6:i386 is not available, but is referred to by another package.
Package libuuid1:i386 is not available, but is referred to by another package.
  e2fsprogs
