I have another question, I try to boot from the QSPI flash, I should use ls1021aqds_spi to compile my u-boot, right? Should I also need to build a SPL?
I just try on my QDS board and after reset without init, CW will prompt for source location. Could you please file on u-boot elf and provide the results.
My u-boot elf for nand boot looks like below:
$ file u-boot
u-boot: ELF 32-bit LSB shared object, ARM, version 1 (SYSV), dynamically linked (uses shared libs), not stripped
