U-Boot Debug using CodeWarrior for QorIQ LS series – ARM V7 ISA
标记 (2)
附件
评论
I have a problem on loading u-boot into our bareboard.
I have a customized LS1021A bareboard, how could I load u-boot into this board?
I compiled a u-boot and tried to attach it by a CodeWarrior TAP, but I always got some JTAG configuration failure.
     Error launching LS1021AQDS_Debug_LS1021AQDS_Attach
     CCSProtocolPlugin : Failed to correctly configure the JTAG chain
Is an on-board programmed u-boot necessary? Or I should change the target initialization file too?
Usually the " Failed to correctly configure the JTAG chain" is generated by the missing of RCW or the wrong configuration of the switches .
Adrian
I have another question, I try to boot from the QSPI flash, I should use ls1021aqds_spi to compile my u-boot, right? Should I also need to build a SPL?
Indeed, to boot from qspi you should used ls1021aqds_spi to compile u-boot.
Hi Adrian,
I have another question: Can I debug the u-boot that boots up from NAND by this way?
I didn't try to debug uboot from NAND, but should be the same. Let me know if doesn't work and I can take a look.
Adrian
Hi Adrian,
I tried it on a bare board, it doesn't work. Maybe the reason is no u-boot in the NAND flash.
I have programmed a RCW file into the NAND flash, so I can gain the JTAG control.
Thanks.
Yes, this is the reason. You have to flash a u-boot with spd-pbl image into the NAND to have all is necessary (rcw, pbi, uboot) for NAND boot.
Adrian
Hi Adrian,
I still have troubles in debuging the NAND boot u-boot.
The NAND boot file "u-boot" is different from the NOR boot file "u-boot", there is another "SPL" part.
How could I debug the NAND boot file?
Do you use LS1021AQDS board? If yes, could you provide your switches settings? Also, did you use u-boot-with-spl-pbl-ls1021aqds_nand.bin?
Adrian
Hi Adrian,
I'm working on a custom board now. I have made a working u-boot for my board.
But still I cannot debug the file "u-boot" normally,
While I reset it(Figure 10), what I get is different from Figure 11, there is no place to set the source code location.
Here is the message:
No source available for "0x00001EC0 (0x00001EC0)() "
I just try on my QDS board and after reset without init, CW will prompt for source location. Could you please file on u-boot elf and provide the results.
My u-boot elf for nand boot looks like below:
$ file u-boot
u-boot: ELF 32-bit LSB shared object, ARM, version 1 (SYSV), dynamically linked (uses shared libs), not stripped
Hi Adrian,
My file information is the same, but while I reset without any init file, here is what's inside the debug window:
100 of_read_number() fdt_support.c:1397 0x00000000
99 of_read_number() fdt_support.c:1397 0x00000000
98 of_read_number() fdt_support.c:1397 0x00000000
3 of_read_number() fdt_support.c:1397 0x00000000
2 of_read_number() fdt_support.c:1397 0x00000000
1 of_read_number() fdt_support.c:1397 0x00000000
If I press "Step Over"/ "Step Into", it will prompt
If I choose Resume/Step Return, it won't prompt anything and I can only Pause or Terminate it.
Besides, I have tried to debug linux kernel and it didn't prompt for source location either.
I delete the whole workspace and redo those steps, but it doesn't work.
Did you still have this issue? What CW version you are using?
%3CLINGO-SUB%20id%3D%22lingo-sub-1103323%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E4%BD%BF%E7%94%A8%20CodeWarrior%20%E9%92%88%E5%AF%B9%20QorIQ%20LS%20%E7%B3%BB%E5%88%97%E8%BF%9B%E8%A1%8C%20U-Boot%20%E8%B0%83%E8%AF%95%20-%20ARM%20V7%20ISA%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1103323%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%BD%BF%E7%94%A8%20CodeWarrior%20%E9%92%88%E5%AF%B9%20QorIQ%20LS%20%E7%B3%BB%E5%88%97%E8%BF%9B%E8%A1%8C%20U-Boot%20%E8%B0%83%E8%AF%95%20-%20ARM%20V7%20ISA%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-TEASER%20id%3D%22lingo-teaser-1103323%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%BD%BF%E7%94%A8%20CodeWarrior%20%E9%92%88%E5%AF%B9%20QorIQ%20LS%20%E7%B3%BB%E5%88%97%E8%BF%9B%E8%A1%8C%20U-Boot%20%E8%B0%83%E8%AF%95%20-%20ARM%20V7%20ISA%3C%2FP%3E%3C%2FLINGO-TEASER%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1103323%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E6%A6%82%E8%BF%B0%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1103337%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%BD%BF%E7%94%A8%20CodeWarrior%20%E4%B8%BA%20QorIQ%20LS%20%E7%B3%BB%E5%88%97%E8%BF%9B%E8%A1%8C%20U-Boot%20%E8%B0%83%E8%AF%95%20-%20ARM%20V7%20ISA%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1103337%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%82%A8%E8%BF%98%E9%81%87%E5%88%B0%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E5%90%97%EF%BC%9F%E6%82%A8%E4%BD%BF%E7%94%A8%E7%9A%84%20CW%20%E7%89%88%E6%9C%AC%E6%98%AF%E4%BB%80%E4%B9%88%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1103335%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%BD%BF%E7%94%A8%20CodeWarrior%20%E4%B8%BA%20QorIQ%20LS%20%E7%B3%BB%E5%88%97%E8%BF%9B%E8%A1%8C%20U-Boot%20%E8%B0%83%E8%AF%95%20-%20ARM%20V7%20ISA%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1103335%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E5%88%9A%E5%88%9A%E5%9C%A8%E6%88%91%E7%9A%84%20QDS%20%E6%9D%BF%E4%B8%8A%E5%B0%9D%E8%AF%95%EF%BC%8C%E5%9C%A8%E6%B2%A1%E6%9C%89%E5%88%9D%E5%A7%8B%E5%8C%96%E7%9A%84%E6%83%85%E5%86%B5%E4%B8%8B%E9%87%8D%E7%BD%AE%E5%90%8E%EF%BC%8CCW%20%E5%B0%86%E6%8F%90%E7%A4%BA%E6%BA%90%E4%BD%8D%E7%BD%AE%E3%80%82%E6%82%A8%E8%83%BD%E5%90%A6%E5%9C%A8%20u-boot%20elf%20%E4%B8%8A%E5%BD%92%E6%A1%A3%E5%B9%B6%E6%8F%90%E4%BE%9B%E7%BB%93%E6%9E%9C%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E7%9A%84%E7%94%A8%E4%BA%8E%20nand%20%E5%90%AF%E5%8A%A8%E7%9A%84%20u-boot%20elf%20%E5%A6%82%E4%B8%8B%E6%89%80%E7%A4%BA%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%24%E6%96%87%E4%BB%B6u-boot%3C%2FP%3E%3CP%3Eu-boot%EF%BC%9AELF%2032%20%E4%BD%8D%20LSB%20%E5%85%B1%E4%BA%AB%E5%AF%B9%E8%B1%A1%EF%BC%8CARM%EF%BC%8C%E7%89%88%E6%9C%AC%201%EF%BC%88SYSV%EF%BC%89%EF%BC%8C%E5%8A%A8%E6%80%81%E9%93%BE%E6%8E%A5%EF%BC%88%E4%BD%BF%E7%94%A8%E5%85%B1%E4%BA%AB%E5%BA%93%EF%BC%89%EF%BC%8C%E6%9C%AA%E5%89%A5%E7%A6%BB%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1103334%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%BD%BF%E7%94%A8%20CodeWarrior%20%E4%B8%BA%20QorIQ%20LS%20%E7%B3%BB%E5%88%97%E8%BF%9B%E8%A1%8C%20U-Boot%20%E8%B0%83%E8%AF%95%20-%20ARM%20V7%20ISA%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1103334%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8CAdrian%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E7%8E%B0%E5%9C%A8%E6%AD%A3%E5%9C%A8%E5%88%B6%E4%BD%9C%E4%B8%80%E5%9D%97%E5%AE%9A%E5%88%B6%E6%9D%BF%E3%80%82%E6%88%91%E5%B7%B2%E7%BB%8F%E4%B8%BA%E6%88%91%E7%9A%84%E4%B8%BB%E6%9D%BF%E5%88%B6%E4%BD%9C%E4%BA%86%E4%B8%80%E4%B8%AA%E5%8F%AF%E8%BF%90%E8%A1%8C%E7%9A%84%20u-boot%E3%80%82%3C%2FP%3E%3CP%3E%E4%BD%86%E6%88%91%E4%BB%8D%E7%84%B6%E6%97%A0%E6%B3%95%E6%AD%A3%E5%B8%B8%E8%B0%83%E8%AF%95%E6%96%87%E4%BB%B6%E2%80%9Cu-boot%E2%80%9D%EF%BC%8C%3C%2FP%3E%3CP%3E%E5%BD%93%E6%88%91%E9%87%8D%E7%BD%AE%E5%AE%83%E6%97%B6%EF%BC%88%E5%9B%BE%2010%EF%BC%89%EF%BC%8C%E6%88%91%E5%BE%97%E5%88%B0%E7%9A%84%E7%BB%93%E6%9E%9C%E4%B8%8E%E5%9B%BE%2011%20%E4%B8%8D%E5%90%8C%EF%BC%8C%E6%B2%A1%E6%9C%89%E5%9C%B0%E6%96%B9%E8%AE%BE%E7%BD%AE%E6%BA%90%E4%BB%A3%E7%A0%81%E4%BD%8D%E7%BD%AE%E3%80%82%3C%2FP%3E%3CP%3E%E4%BB%A5%E4%B8%8B%E6%98%AF%E6%B6%88%E6%81%AF%E5%86%85%E5%AE%B9%EF%BC%9A%3C%2FP%3E%3CBLOCKQUOTE%3E%0A%3CP%3E%E6%B2%A1%E6%9C%89%E5%8F%AF%E7%94%A8%E4%BA%8E%E2%80%9C0x00001EC0%20(0x00001EC0)()%E2%80%9D%E7%9A%84%E6%BA%90%20%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1103333%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%BD%BF%E7%94%A8%20CodeWarrior%20%E4%B8%BA%20QorIQ%20LS%20%E7%B3%BB%E5%88%97%E8%BF%9B%E8%A1%8C%20U-Boot%20%E8%B0%83%E8%AF%95%20-%20ARM%20V7%20ISA%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1103333%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%82%A8%E4%BD%BF%E7%94%A8%20LS1021AQDS%20%E6%9D%BF%E5%90%97%EF%BC%9F%E5%A6%82%E6%9E%9C%E6%98%AF%EF%BC%8C%E6%82%A8%E8%83%BD%E6%8F%90%E4%BE%9B%E6%82%A8%E7%9A%84%E5%BC%80%E5%85%B3%E8%AE%BE%E7%BD%AE%E5%90%97%EF%BC%9F%E5%8F%A6%E5%A4%96%EF%BC%8C%E6%82%A8%E6%98%AF%E5%90%A6%E4%BD%BF%E7%94%A8%E4%BA%86%20u-boot-with-spl-pbl-ls1021aqds_nand.bin%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%98%BF%E5%BE%B7%E9%87%8C%E5%AE%89%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1103332%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%BD%BF%E7%94%A8%20CodeWarrior%20%E4%B8%BA%20QorIQ%20LS%20%E7%B3%BB%E5%88%97%E8%BF%9B%E8%A1%8C%20U-Boot%20%E8%B0%83%E8%AF%95%20-%20ARM%20V7%20ISA%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1103332%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8CAdrian%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E5%9C%A8%E8%B0%83%E8%AF%95%20NAND%20%E5%90%AF%E5%8A%A8%20u-boot%20%E6%97%B6%E4%BB%8D%E7%84%B6%E9%81%87%E5%88%B0%E9%BA%BB%E7%83%A6%E3%80%82%3C%2FP%3E%3CP%3ENAND%E5%90%AF%E5%8A%A8%E6%96%87%E4%BB%B6%E2%80%9Cu-boot%E2%80%9D%E4%B8%8ENOR%E5%90%AF%E5%8A%A8%E6%96%87%E4%BB%B6%E2%80%9Cu-boot%E2%80%9D%E4%B8%8D%E5%90%8C%EF%BC%8C%E5%A4%9A%E4%BA%86%E4%B8%80%E4%B8%AA%E2%80%9CSPL%E2%80%9D%E9%83%A8%E5%88%86%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E5%A6%82%E4%BD%95%E8%B0%83%E8%AF%95%20NAND%20%E5%90%AF%E5%8A%A8%E6%96%87%E4%BB%B6%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1103331%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%BD%BF%E7%94%A8%20CodeWarrior%20%E4%B8%BA%20QorIQ%20LS%20%E7%B3%BB%E5%88%97%E8%BF%9B%E8%A1%8C%20U-Boot%20%E8%B0%83%E8%AF%95%20-%20ARM%20V7%20ISA%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1103331%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%98%AF%E7%9A%84%EF%BC%8C%E5%B0%B1%E6%98%AF%E8%BF%99%E4%B8%AA%E5%8E%9F%E5%9B%A0%E3%80%82%E6%82%A8%E5%BF%85%E9%A1%BB%E5%B0%86%E5%B8%A6%E6%9C%89%20spd-pbl%20%E6%98%A0%E5%83%8F%E7%9A%84%20u-boot%20%E5%88%B7%E5%85%A5%20NAND%EF%BC%8C%E4%BB%A5%E8%8E%B7%E5%BE%97%20NAND%20%E5%90%AF%E5%8A%A8%E6%89%80%E9%9C%80%E7%9A%84%E4%B8%80%E5%88%87%EF%BC%88rcw%E3%80%81pbi%E3%80%81uboot%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%98%BF%E5%BE%B7%E9%87%8C%E5%AE%89%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1103330%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%BD%BF%E7%94%A8%20CodeWarrior%20%E4%B8%BA%20QorIQ%20LS%20%E7%B3%BB%E5%88%97%E8%BF%9B%E8%A1%8C%20U-Boot%20%E8%B0%83%E8%AF%95%20-%20ARM%20V7%20ISA%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1103330%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8CAdrian%EF%BC%9A%3C%2FP%3E%3CP%3E%E6%88%91%E5%9C%A8%E8%A3%B8%E6%9D%BF%E4%B8%8A%E8%AF%95%E8%BF%87%EF%BC%8C%E4%BD%86%E6%98%AF%E4%B8%8D%E8%B5%B7%E4%BD%9C%E7%94%A8%E3%80%82%E5%8F%AF%E8%83%BD%E6%98%AF%E5%9B%A0%E4%B8%BANAND%20flash%E4%B8%AD%E6%B2%A1%E6%9C%89u-boot%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E5%B7%B2%E5%B0%86%20RCW%20%E6%96%87%E4%BB%B6%E7%BC%96%E7%A8%8B%E5%88%B0%20NAND%20%E9%97%AA%E5%AD%98%E4%B8%AD%EF%BC%8C%E5%9B%A0%E6%AD%A4%E6%88%91%E5%8F%AF%E4%BB%A5%E8%8E%B7%E5%BE%97%20JTAG%20%E6%8E%A7%E5%88%B6%E3%80%82%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1103329%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%BD%BF%E7%94%A8%20CodeWarrior%20%E4%B8%BA%20QorIQ%20LS%20%E7%B3%BB%E5%88%97%E8%BF%9B%E8%A1%8C%20U-Boot%20%E8%B0%83%E8%AF%95%20-%20ARM%20V7%20ISA%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1103329%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E6%B2%A1%E6%9C%89%E5%B0%9D%E8%AF%95%E4%BB%8ENAND%E8%B0%83%E8%AF%95uboot%EF%BC%8C%E4%BD%86%E5%BA%94%E8%AF%A5%E6%98%AF%E4%B8%80%E6%A0%B7%E7%9A%84%E3%80%82%E5%A6%82%E6%9E%9C%E4%B8%8D%E8%B5%B7%E4%BD%9C%E7%94%A8%EF%BC%8C%E8%AF%B7%E5%91%8A%E8%AF%89%E6%88%91%EF%BC%8C%E6%88%91%E5%8F%AF%E4%BB%A5%E7%9C%8B%E7%9C%8B%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%98%BF%E5%BE%B7%E9%87%8C%E5%AE%89%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1103328%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%BD%BF%E7%94%A8%20CodeWarrior%20%E4%B8%BA%20QorIQ%20LS%20%E7%B3%BB%E5%88%97%E8%BF%9B%E8%A1%8C%20U-Boot%20%E8%B0%83%E8%AF%95%20-%20ARM%20V7%20ISA%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1103328%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8CAdrian%EF%BC%9A%3C%2FP%3E%3CP%3E%E6%88%91%E8%BF%98%E6%9C%89%E4%B8%80%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%9A%E6%88%91%E5%8F%AF%E4%BB%A5%E9%80%9A%E8%BF%87%E8%BF%99%E7%A7%8D%E6%96%B9%E5%BC%8F%E8%B0%83%E8%AF%95%E4%BB%8E%20NAND%20%E5%90%AF%E5%8A%A8%E7%9A%84%20u-boot%20%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1103327%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%BD%BF%E7%94%A8%20CodeWarrior%20%E4%B8%BA%20QorIQ%20LS%20%E7%B3%BB%E5%88%97%E8%BF%9B%E8%A1%8C%20U-Boot%20%E8%B0%83%E8%AF%95%20-%20ARM%20V7%20ISA%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1103327%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E7%A1%AE%E5%AE%9E%EF%BC%8C%E8%A6%81%E4%BB%8E%20qspi%20%E5%90%AF%E5%8A%A8%EF%BC%8C%E6%82%A8%E5%BA%94%E8%AF%A5%E4%BD%BF%E7%94%A8%20ls1021aqds_spi%20%E6%9D%A5%E7%BC%96%E8%AF%91%20u-boot%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1103326%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%BD%BF%E7%94%A8%20CodeWarrior%20%E4%B8%BA%20QorIQ%20LS%20%E7%B3%BB%E5%88%97%E8%BF%9B%E8%A1%8C%20U-Boot%20%E8%B0%83%E8%AF%95%20-%20ARM%20V7%20ISA%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1103326%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CP%3E%E6%88%91%E8%BF%98%E6%9C%89%E4%B8%80%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%8C%E6%88%91%E5%B0%9D%E8%AF%95%E4%BB%8E%20QSPI%20%E9%97%AA%E5%AD%98%E5%90%AF%E5%8A%A8%EF%BC%8C%E6%88%91%E5%BA%94%E8%AF%A5%E4%BD%BF%E7%94%A8%20ls1021aqds_spi%20%E6%9D%A5%E7%BC%96%E8%AF%91%E6%88%91%E7%9A%84%20u-boot%EF%BC%8C%E5%AF%B9%E5%90%97%EF%BC%9F%E6%88%91%E8%BF%98%E9%9C%80%E8%A6%81%E6%9E%84%E5%BB%BA%20SPL%20%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1103325%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%BD%BF%E7%94%A8%20CodeWarrior%20%E4%B8%BA%20QorIQ%20LS%20%E7%B3%BB%E5%88%97%E8%BF%9B%E8%A1%8C%20U-Boot%20%E8%B0%83%E8%AF%95%20-%20ARM%20V7%20ISA%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1103325%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E9%80%9A%E5%B8%B8%EF%BC%8C%E2%80%9C%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3E%E6%97%A0%E6%B3%95%E6%AD%A3%E7%A1%AE%E9%85%8D%E7%BD%AEJTAG%E9%93%BE%3C%2FSPAN%3E%E2%80%9D%E6%98%AF%E7%94%B1%E4%BA%8E%E7%BC%BA%E5%B0%91RCW%E6%88%96%E5%BC%80%E5%85%B3%E9%85%8D%E7%BD%AE%E9%94%99%E8%AF%AF%E9%80%A0%E6%88%90%E7%9A%84%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%98%BF%E5%BE%B7%E9%87%8C%E5%AE%89%20%3C%2FP%3E%3C%2FLINGO-BODY%3E
无评分
版本历史
最后更新:
‎06-11-2014 01:31 AM
更新人:
