code warrior 5.9.0 high light
2,638 次查看
fanziyu
Hello every one,
for reason, I have to use code warrior 5.9.0,it is not easy to use.Now,I have a ploblem:
I want to high light the same word but do not kown how to do it.
标记 (1)
2,454 次查看
ZhangJennie
HI
Can you illustrate your problem with  screenshots? Thanks.
TIC
2,454 次查看
fanziyu
看代码的时候,鼠标双击某个变量,这个界面中所有相同变量都会高亮显示。我想达到这个效果。code warrior IDE Version 5.9.0可以设置成这样么?效果跟下面一样。谢谢
Double click on the variable to highlight the same variable in the same interface,Thanks!
I want code warrior IDE Version 5.9.0  have the same functionality,How to do it?
2,454 次查看
ZhangJennie
HI Wu,
NO, classic CW doesn't have this feature.
TIC
