Why can't I drag files into File compare window any more?
789件の閲覧回数
phil_b
Using CodeWarrior V5.1, I have always been able to drag files/folders from Windows Explorer into the Compare Files Setup window (Search, File Compare). I recently installed CodeWarrior V10.6.4, so could this have caused the issue?
621件の閲覧回数
ZhangJennie
Hi Phil,
I also have CodeWarrior V10.6.4 and CodeWarrior v5.1 installed on my computer. I can drag file to CW5.1 Compare Files Setup window without problem.
you may try to uninstall CW5.1 then reinstall it, check if this feature can work normally?
Jennie Zhang
