Hi Phil,
I also have CodeWarrior V10.6.4 and CodeWarrior v5.1 installed on my computer. I can drag file to CW5.1 Compare Files Setup window without problem.
you may try to uninstall CW5.1 then reinstall it, check if this feature can work normally?
Jennie Zhang
