What is error 1
What is error 1
1,388件の閲覧回数
barbercolman
Sometimes when compiling with cw10.2 I get a compiler error that is just "Error 1" with a Type of "c/C++ problems". Does any one know what causes this error or how to fix it?
1,252件の閲覧回数
BlackNight
look like the error parser might not parsed the error message correctly, or the compiler has produced a message 'out of format'. Have a look in the Console view (menu Window > Show View > Console in case you do not have it open). The Console view shows the full output of the compiler, so you should be see the problem there.
Hope this helps,
Erich
