Hello
No you cannot load a configuration from command line component.
The configuration must be known when HI-WAVE is started.
Instead you can use option -Prod on the command line when starting HI-WAVE to specify the configuration (.ini file) you want to use.
Available command line options are listed in section "Command Line Options" in debugger manual.
CrasyCat
