What debugger command could "open configuration" in Hi-wave?
2,477 次查看
DanielTan
In Hi-wave, "File->Open Configuration" could a load a .ini file.
Could I use a debugger command in Command component to load a .ini file?
标记 (1)
1,936 次查看
CrasyCat
Specialist III
Hello
No you cannot load a configuration from command line component.
The configuration must be known when HI-WAVE is started.
Instead you can use option -Prod on the command line when starting HI-WAVE to specify the configuration (.ini file) you want to use.
Available command line options are listed in section "Command Line Options" in debugger manual.
CrasyCat
897 次查看
tonglya
Use OPENPROJECT command in command window as below.
OPENPROJECT "D:\Program Files (x86)\Freescale\CWS12v5.2\Prog\project.ini"
1,937 次查看
CrasyCat
Specialist III
Hello
CrasyCat
%3CLINGO-SUB%20id%3D%22lingo-sub-181523%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E4%BB%80%E4%B9%88%E8%B0%83%E8%AF%95%E5%99%A8%E5%91%BD%E4%BB%A4%E5%8F%AF%E4%BB%A5%22%E6%89%93%E5%BC%80%20Hi-wave%20%E4%B8%AD%E7%9A%84%E9%85%8D%E7%BD%AE%22%20%EF%BC%9F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-181523%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%9C%A8%20Hi-wave%20%E4%B8%AD%EF%BC%8C%22File-%26gt%3BOpen%20Configuration%22%20%E5%8F%AF%E4%BB%A5%E5%8A%A0%E8%BD%BD%20.ini%20%E6%96%87%E4%BB%B6%E3%80%82%E9%94%89%E5%88%80%3C%2FP%3E%3CP%3E%E6%88%91%E5%8F%AF%E4%BB%A5%E5%9C%A8%E5%91%BD%E4%BB%A4%E5%85%83%E5%99%A8%E4%BB%B6%E4%B8%AD%E4%BD%BF%E7%94%A8%E8%B0%83%E8%AF%95%E5%99%A8%E5%91%BD%E4%BB%A4%E6%9D%A5%E5%8A%A0%E8%BD%BD%20.ini%20%E5%90%97%E6%96%87%E4%BB%B6%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-181523%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E6%A6%82%E8%BF%B0%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2302260%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20What%20debugger%20command%20could%20%22open%20configuration%22%20in%20Hi-wave%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2302260%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CFONT%20color%3D%22%23000000%22%3E%E5%9C%A8%E5%91%BD%E4%BB%A4%E7%AA%97%E5%8F%A3%E4%B8%AD%E4%BD%BF%E7%94%A8%20OPENPROJECT%20%E5%91%BD%E4%BB%A4%EF%BC%8C%E5%A6%82%E4%B8%8B%E6%89%80%E7%A4%BA%E3%80%82%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20color%3D%22%23000000%22%3EOPENPROJECT%22D%3A%5CProgram%20Files%20(x86)%5CFreescale%5CCWS12v5.2%5CProg%5Cproject.ini%22%3C%2FFONT%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-181524%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20What%20debugger%20command%20could%20%22open%20configuration%22%20in%20Hi-wave%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-181524%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHello%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E4%B8%8D%EF%BC%8C%E6%82%A8%E6%97%A0%E6%B3%95%E4%BB%8E%E5%91%BD%E4%BB%A4%E8%A1%8C%E5%85%83%E5%99%A8%E4%BB%B6%E5%8A%A0%E8%BD%BD%E9%85%8D%E7%BD%AE%E3%80%82%3C%2FP%3E%3CP%3E%E5%90%AF%E5%8A%A8%20HI-WAVE%20%E6%97%B6%E5%BF%85%E9%A1%BB%E7%9F%A5%E9%81%93%E9%85%8D%E7%BD%AE%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%9C%A8%E5%90%AF%E5%8A%A8%20HI-WAVE%20%E6%97%B6%E4%BD%BF%E7%94%A8%E5%91%BD%E4%BB%A4%E8%A1%8C%E9%80%89%E9%A1%B9%20-Prod%20%E6%9D%A5%E6%8C%87%E5%AE%9A%E8%A6%81%E4%BD%BF%E7%94%A8%E7%9A%84%E9%85%8D%E7%BD%AE%EF%BC%88.ini%20%E6%96%87%E4%BB%B6%EF%BC%89%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E5%8F%AF%E7%94%A8%E7%9A%84%E5%91%BD%E4%BB%A4%E8%A1%8C%E9%80%89%E9%A1%B9%E5%88%97%E4%BA%8E%E8%B0%83%E8%AF%95%E5%99%A8%E6%89%8B%E5%86%8C%22%E5%91%BD%E4%BB%A4%E8%A1%8C%E9%80%89%E9%A1%B9%22%20%E9%83%A8%E5%88%86%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3ECrasyCat%3C%2FP%3E%3C%2FLINGO-BODY%3E
