Sudden Error Shown: "An internal error occurred during: "Debug Database Initialization"."
1,871 次查看
dcongie
I've been using CodeWarrior 10 for several years however recently I received an error which prevents me to perform Flash Program or debugging.
The error is showing at the start of the IDE even there's no project opened.
I've tried uninstalling and installing the Microsoft Visual C++ Redistriutable packages but it seems not related to the problem.
I've attached the diagnostics for more information.
1,751 次查看
ZhangJennie
Hi Donald,
Please check if solution in this link can also work you.
https://community.nxp.com/message/368501
Jun Zhang
1,752 次查看
ZhangJennie
Hi Donald,
Jun Zhang
1,751 次查看
dcongie
I followed the instruction to delete the .metadata folder and it fixed my issue.
Thanks!
1,751 次查看
ZhangJennie
Hi dcongie,
Good! Thanks for the sharing.
Best Regards
Jun Zhang
