Using CodeWarrior for MCU, v10.7, on S12Z target, I am not able to aligned global variables as specified in the documentation:
#pragma cpp1x on
int foo __attribute__ ((aligned (4)));
void main(void) {
static_assert(__alignof__(foo) == 1, "SHOULD BE WRONG"); /* compilation OK. But it should fail */
static_assert(__alignof__(foo) == 4, "SHOULD BE OK"); /* compilation failed. But it should be ok? */
compiled with
mwccs12lisa.exe alignment.c
results in the compilation error
Compiler:
# File: alignment.c
# 5: static_assert(__alignof__(foo) == 4, "SHOULD BE OK"); /* compilation failed. But it should be ok? */
# Error: ^^^^^^^^^^^^^^
# static assert check 'SHOULD BE OK' failed
What did I miss?
Thanks for your support,
Pascal.
