S12Z: __attribute__ ((aligned (4))) has no effect
3,472件の閲覧回数
pascalbrand
Using CodeWarrior for MCU, v10.7, on S12Z target, I am not able to aligned global variables as specified in the documentation:
#pragma cpp1x on
int foo __attribute__ ((aligned (4)));
void main(void) {
    static_assert(__alignof__(foo) == 1, "SHOULD BE WRONG"); /* compilation OK. But it should fail */
    static_assert(__alignof__(foo) == 4, "SHOULD BE OK"); /* compilation failed. But it should be ok? */
compiled with
mwccs12lisa.exe alignment.c
results in the compilation error
Compiler:
# File: alignment.c
# 5: static_assert(__alignof__(foo) == 4, "SHOULD BE OK"); /* compilation failed. But it should be ok? */
# Error: ^^^^^^^^^^^^^^
# static assert check 'SHOULD BE OK' failed
What did I miss?
Thanks for your support,
Pascal.
6 返答(返信)
3,139件の閲覧回数
pascalbrand
Here is a 7zip of my project.
Pascal;
3,139件の閲覧回数
pascalbrand
Hello ZhangJennie,
Have you been able to reproduce what I am describing?
Do you need extra info?
Pascal.
3,139件の閲覧回数
ZhangJennie
Hi Pascal.
Sorry for the late, I was not in office these days.
I tested your project on my side and I reproduced your problem.
I will contact developer for it.
Will keep you informed.
Jennie Zhang
3,139件の閲覧回数
pascalbrand
Hello ZhangJennie,
any news?
Pascal.
3,139件の閲覧回数
ZhangJennie
Hi Pascal.
I reproduced your problem and escalated this problem to development team.with report number CMPLG-41
I will keep you informed if I get any update there.
Jennie Zhang
3,139件の閲覧回数
ZhangJennie
Hello Pascal,
Can you please send me your demo project for your problem?
Thanks.
Jennie Zhang
