Regarding OSBDM debugger interface with code warrior
2,565 次查看
maharajsankaran
Hi all,
I am using the MM9z1J638 sensor with OSBDM debugger. but I am unable to connect with target through OSBDM interface.
It seems need to install some driver for this.but i can't get the driver from freescale site.Please give some suggestion to slove this problem
Thanks in advance.
Maharaj S
4 回复数
2,447 次查看
ZhangJennie
You can also download the latest OSBDM driver from this url:
http://www.pemicro.com/osbdm/
Zhang Jun
2,447 次查看
maharajsankaran
Hi All,
OSBDM is working fine. the problem due to my evaluation board only. I check with another evalution board, its working fine.
2,447 次查看
maharajsankaran
Thanks all and Zhang Jun.
BR// Maharaj S
2,447 次查看
ZhangJennie
you are welcome!
Zhang Jun
