I'm not having much luck here. I am using CW 10.2 and the PE Micro USB based programmer called the USB Multilink Interface. It's worked fine for testing but now I want to flash units to leave the building and I want to protect the code against modification and from being read out of the device. I can't find a way to do this and this programmer has no standalone app. Maybe there is some third party app out there.
I have searched this forum and found a good way to flash the main code into boards quickly and without having to rebuild every time by starting the debugger, but won't protect the flash.
How can I do this? Do I need to hand modify my S19 file to include the registers or is there an easier way? If I did modify the .S19 file, would code warrior even send those protection settings anyway? Do I have no choice but to buy a more expensive programmer?
Thanks!
Michael
