Programming HCS08 on Raspberry Pi
2,876 次查看
edasanli
I need to programming MC9S08PA4 on Raspberry Pi. I tried to install Code Warrior on RPi, but RPi is based on ARM so it could not install. I don't need to developing, I have a s19 file, just need to programming my microprocessor.
Is there someone have a solution about that?
Have a nice day.
-Eda
#mc9s08pa4‌raspberry pi‌
2,820 次查看
vicentegomez
In order to program the S08 you will need an OSBDM, those are available on several evaluation boards or in programmers like the Universal multilink from P&E.
or you can create your own OSBDM, please check
PEmicro | Experts in Embedded tools for Flash Programming and Development
I hope this will help you
Vicente
2,820 次查看
edasanli
I have S08PT60-EVK and PE Micro Multilink. But I need an application for programming, which can be installed on Raspberry Pi.
