Programming HCS08 on Raspberry Pi
2,904件の閲覧回数
edasanli
I need to programming MC9S08PA4 on Raspberry Pi. I tried to install Code Warrior on RPi, but RPi is based on ARM so it could not install. I don't need to developing, I have a s19 file, just need to programming my microprocessor.
Is there someone have a solution about that?
Have a nice day.
-Eda
#mc9s08pa4‌raspberry pi‌
2,848件の閲覧回数
vicentegomez
In order to program the S08 you will need an OSBDM, those are available on several evaluation boards or in programmers like the Universal multilink from P&E.
or you can create your own OSBDM, please check
PEmicro | Experts in Embedded tools for Flash Programming and Development
I hope this will help you
Vicente
2,848件の閲覧回数
edasanli
I have S08PT60-EVK and PE Micro Multilink. But I need an application for programming, which can be installed on Raspberry Pi.
