MPC5604P resets after removing Debugger
shrikant_oak
I am using MPC5604P controller for my application, I have evaluation board TRK - MPC5604P. Currently using the CW ( Version: 10.2, Build Id:120126) for Flashing the code to controller. A strange issue I am facing that is whenever Debugger (Multilink Universal) is connected the MPC5604P works fine. But as soon as I remove Debugger MPC5604P keeps resetting after every 4mSec & on time is only 4uSec.
Please suggest.
Thanks & Regards,
Shrikant Oak
Monica
Senior Contributor III
Hey there Shrikant!
How's the project going? Did the watchdog help?
Regards!
ioseph_martinez
Sounds like the watchdog. I am not really sure on this device but the debugger may be inhibitting the watchdog by some configuration but as soon as you remove it watchdog is free to act.
Try having watchdog fed on your code or disable from the beginning before doing anything.
