MC9S08PA16 Does not appear as a device when a make a new bareboard project
nicholasrainsfo
I need to flash a device that I am testing with preexisting software.  The vendor told me I need to use MC9S08PA16, however it does not appear under HCS08.  Is there a way to install this board into the list of devices manually that I am not seeing?
ZhangJennie
Hi.
I checked your screenshot. there is no item under HCS08PA family which is not normal.
I attached the video of my testing.
I suggest you uninstall your CW then reinstall CW10.7 then test same again.
Jennie Zhang
ZhangJennie
Hi.
Jennie Zhang
