Locating RAM variables
3,253 次查看
Ben
Senior Contributor I
Hello
I built several RAM arias in the project.
Please help me with CW C commands that will enable locating variables in a specific RAM zone.
(like SECTION in CW assembly).
TIA Benny
标记 (3)
2,881 次查看
tiagomachado
In CW help, search for "@address".
From help menu:
Global Variable Address Modifier (@address)
Use the global variable address modifier to assign global variables to specific addresses.....
int glob @0x0500 = 10; // global variable "glob" is at 0x0500, initialized with 10
There are many other ways to use this modifier. Look there.
Hope it helps.
4 回复数
2,881 次查看
loosePointer
Have a look in the Linker Command File documentation.
You can tell the Linker to Place a symbol in a specific section, and address in your ".lcf"
This is how we place our software version at a known location.
___SOFTWARE_REVISION = 1;
  WRITEW(0x05000000 + ___SOFTWARE_REVISION);
You could substitute the symbol for your array.  But be carfull with the size of the array and the section it is in.
2,881 次查看
Ben
Thanks James, I'll have to check the lcf options. Do you have mapping sample in lcf?
2,882 次查看
tiagomachado
From help menu:
Hope it helps.
2,881 次查看
Ben
Thanks Tiago. I am trying it.
