Lines of Code (LOC) Codewarrior v11.0
2,061 次查看
christinar
Hello together,
How can I find out the lines of code of my program? I'm using CodeWarrior v11.0. I found something in the .map file (Module Statistic with Data, Code and Const for each object) but don't think that's the LOC, because it's a lot more than my program.
Where can I find the LOC?
Thank you in advance
Christina
标记 (1)
4 回复数
1,886 次查看
BlackNight
Hi Christina,
you can use CLOC -- Count Lines of Code  for this.
I hope this helps,
Erich
1,886 次查看
christinar
Thanks, but do you know if this information is in a file that CodeWarrior generates?
1,886 次查看
BlackNight
It is not directly availalbe, but you can use the postbuild step for generating this.
Executing Multiple Commands as Post-Build Steps in Eclipse | MCU on Eclipse
Erich
1,886 次查看
christinar
Ok thank you very much!
Kind regards,
Christina
